stalls during sharp turns
Old 05-07-2013, 06:00 PM
KB-K5 BLAZER's Avatar
KB-K5 BLAZER is on a distinguished road
Ok I just bought a reconditioned Edelbrock Carb and it solved the problem with bogging at WOT and it drives awesome. So I obviously did something wrong on the Carter AFB or it could of even been the spacer, it had a open spacer when I purchased the spacer that was recommended for the GM, I noticed in the instructions they advised not to use an open spacer. With it finally running normal I was able to determine that the stalling while turning right is a short in the steering column. For now I just put the steering wheel all the way up and it works fine, it really needs to be replaced, next project.........
Old 05-18-2013, 06:35 AM
Final update, I got the steering wheel tightened, and finally got the new carb tuned right. Finally running great.
Old 08-03-2016, 08:03 PM
danaandmeegz's Avatar
danaandmeegz is on a distinguished road
Wou;d you suspect a carb bowl problem if my 1986 Astro Van with the 4.3L, if when I turn to the right and it stalls. It seems to be getting worse (maybe the summer heat) since i haven't seen the problem on the way to work in the morning.
I swear it will die if I turn the wheel and not even roll over 5 mph.
Left turns no problem
Recent tune up
Restarts immediately
idles smooth
Maybe something in the steering column?
I found on Google, people who fixed it with repairs to ignition switch and tilt steering column issues.
I have a tilt steering wheel that moves a lot when you press on it (I have seen the posts on fixing the screws what loosen up, just never got around to fixing it yet).
So I went out and turned the wheel and it stayed running until I pressed on the wheel and it essentially presses a lever back down that the ignition switch raises to start. Guess I will be taking it apart to fix the loose screws now.
I suspect in some cases an ignition switch is needed, but suspect the steering wheel if it moves from using it to climb into the drivers seat for decades
Brandon Koharchik
10-30-2013 09:52 AM
ComputerNerdBD
23
05-15-2012 05:46 PM
ComputerNerdBD
02-29-2012 08:09 PM
CNYCountryKidd
11-20-2009 09:16 AM
abadinalbany
11-05-2008 04:48 PM
Quick Reply: stalls during sharp turns
