tbi issues....1990 5.7
Old 11-13-2013, 06:34 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Question
so if you pour gas down the throttle or carb and it runs how can the distributor be bad?
Old 11-14-2013, 07:04 AM
BigBobsk5Blazer's Avatar
BigBobsk5Blazer is on a distinguished road
Originally Posted by THePaRaSiTE5771
That is false, there is no cam or crank sensor in the distributor. Only sensor in the distributor is the ICM module.
You are right. They didn't start doing the cam/crank thing until the Vortec setup I believe 1996+.
The first generation had HEI then went to ICM module with external coil. The ICM module was probably corroded, I just replaced the one I had. He probably should have just changed that but the who distributor most likely was not the much.
Old 11-14-2013, 08:13 AM
tattime's Avatar
tattime is on a distinguished road
@Parasite ......there IS a pickup in the distributor that sends a signal to the ecm that tells it to pulse the injectors...it performs the same function ad the cam shaft sensors that was used in later model vehicles ...
Old 11-14-2013, 08:47 AM
tattime's Avatar
@Parasite ....There is a pick up inside the distributor what does the same job as the camshaft sensor......Sends signal to the ECM which sends a signal to pulse the injectors...
daviddodge
08-08-2015 08:38 PM
Randomtask2
08-06-2014 12:34 PM
deathman
08-14-2011 11:25 PM
maverik78
Performance & Brainstorming
04-11-2010 10:05 PM
SniperX13
04-29-2007 12:48 AM
Quick Reply: tbi issues....1990 5.7
