Transmission Filler tube 72 blazer
My blazer is leaking tranny fluid like a hobo after a long night of drinking. The O-ring on the trans filler tube was replaced but I am wondering if the dipstick is not the right one. I think it may be too short, the tube might be too long, thus me adding WAY more than I should have. The gasket on the pan was replaced about 7 months ago.
How long should the dipstick be on a small block 350?
Further thoughts? Thank you in advance.
yes. transmission
on mine the transmission filler tube is all the way in the back of the engine. When I changed the o-ring on the tube, I kept checking the dipstick while adding a little more and nothing was registering after 2 quarts or so Then I finally got a reading. Does this make sense?
According to someone who looked at it, they said it might be the bolt near the filler tube. I am almost certain it was installed all the way seated then sealed around it. Someone said that the bolt needs to be tight but you can tighten it too much and then f up the something or the other. Still learning so sorry for the vagueness. Don't know the correct terminology.
chipjumper
10-27-2010 09:31 AM
riceh8r0512
09-10-2007 08:50 PM
