how eval condition of 203 transfer case
Old 01-23-2009, 05:15 PM
offskooring's Avatar
offskooring is an unknown quantity at this point
Default how eval condition of 203 transfer case
I have a 77 K5, th350 with broke down np203. I am in the process of scouting out another 203. Does anyone have any suggestions about the questions i need to ask when buying one? I know to make sure spline counts match...but i don't know what to look for orwhat to ask regarding the condition of the transfer case...
thanks for your time
Old 01-23-2009, 07:11 PM
Default RE: how eval condition of 203 transfer case
What is wrong with your 203? What is it doing? If it is busted up, why not rebuild it?
If you just want something to swap in, then you should just verify that the input spline count is the same and that it has the same size yokes front and back. Then just run it through the gears and make sure that everything is working properly.
Flyfishen
06-18-2019 11:22 AM
fatsjames
11-06-2009 05:35 PM
root'n
09-16-2009 06:27 PM
importcoloh
Lifting Tech
06-12-2009 07:54 PM
pyp5y
06-20-2006 01:05 PM
Quick Reply: how eval condition of 203 transfer case
