Rear window motor problems
Old 12-22-2010, 04:32 PM
smg614's Avatar
smg614 is on a distinguished road
Default Rear window motor problems
I have an 84 full size jimmy and having issues with the window going up and down. It has new glass and seals, but still not enough strength to move. Does anyone know where i can get a new motor? I have ordered a new cable from LMC, but have a feeling thats not going to solve the problem.
Old 12-22-2010, 04:48 PM
Check the ground to the motor. I have seen a number of weak rear motors be due to an inadequate ground to the motor which grounds through the tailgate hinge. I would just run a new ground along with the rest of the wires into the tailgate. See if that helps things.
If not, the next thing might be to remove the regulator and make sure that it is lubed up good.
Beyond that, the motors are EXPENSIVE! I have two extras not including the one in my power window'd tailgate. I have the extras because of the problems that most people run into with a rear power window.
Old 12-23-2010, 01:12 PM
smg614's Avatar
Thanks for the info, but just in case I need extras, where can a motor be found? I've searched the internet and haven't been able to locate one.
Old 12-23-2010, 01:31 PM
They're out there. Google "K5 rear window motor" and see what turns up.
Old 12-24-2010, 12:08 AM
jpimp's Avatar
jpimp is on a distinguished road
summit has them
http://www.summitracing.com/parts/AAZ-42-20/
Old 01-14-2011, 09:59 AM
racer77's Avatar
racer77 is on a distinguished road
i just ordered one for mine trough advanceautoparts.com 60 some dollars
e602
91
03-08-2015 04:53 PM
stewie455
01-22-2012 09:02 PM
THePaRaSiTE5771
06-06-2010 10:15 AM
billynjuls
02-16-2008 04:24 PM
jumper02
06-08-2006 12:09 AM
Quick Reply: Rear window motor problems
