2000 Chevy blazer rear wiper motor problem
When i turn on my rear wiper motor the arm only comes up part way and then makes a vibrating sound. Seems like the arm is tight on the shaft. If i push it up with my hand it works, but as soon as I shut it off and turn it on it gets stuck again. Any ideas.
Thanks
Thanks
I checked it out a little farther. Even though the arm is tight on the shaft I removed it and turned on the motor and it worked fine. Turns out the point where they attach together is stripped. Going to try a new wiper arm and I am hoping that works and I didn't let the motor shaft get stripped. Hope that this helps
I replaced the arm today and it still did not work. I assumed the shaft on the motor was stripped so got a new motor and all worked well. Just to make sure take the arm off and make sure the shaft turns as is supposed to. If it does start with the arm and do what i did.
litterbox99
09-22-2014 05:39 PM
pusher_sr
03-06-2005 04:26 AM
