93 needing some brighter lights
hey im getting a 93 blazer and i know im going to want some brighter lights what do you guys recomend i do ?
i also have a 97 s-10 that could use a lot better lights too thanks BF
RE: 93 needing some brighter lights
Mount 4 driving lights on top and 2 on the bumper!!!
id say the best bet would be silverstars or HIDs
If you are doing HIDs, you should look into a projector setup as HIDs + factory headlight assem = glare for other drivers
93 is a bit more difficult than the later years due to the craptastic sealed beams but there is hope check out This Link I strongly suggest the harness directly under the new light fixture (new fixture allows just changing the bulb instead of the entire unit) for a little more oomph in the power to your lights (these 2 things are pretty much essential if you plan on a hid conversion) another option (way cheaper) that I just seen the other day at pep boys is the silverstar sealed beam lights that are a direct replacement for your o.e. lights (dont know anybody who has used these yet so I cannot offer any info on how bright they are other than 5000k according to the packaging)
xJakeLIKEShisBLAZERx
02-11-2018 07:00 PM
Nick101
02-10-2015 06:29 PM
