Flat towing a 1998 Blazer - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 03-29-2009, 02:57 PM
JSolCanby is on a distinguished road
Default Flat towing a 1998 Blazer
Hi - I have a motor coach and would like to be able to tow my 1998 Blazer 4 wheels down rather than using a tow dolly. The Blazer is an automatic 4X4. My mechanic says that as long as its in neutral and the transfer case (electronic switch) is in neutral that I should not have any problems. I'm looking for 2nd and 3rd opinions before I mount a tow bar on the front. Any comments or advice is appreciated.
Thanks. Joe
Old 03-29-2009, 06:37 PM
rriddle3's Avatar
Here's what your owner's manual says:
If your vehicle has four
-wheel-drive it cannot be dinghy towed (towing with all four wheels on the ground). A four-wheel-drive vehicle must be towed by flatbed.
Take it for what it's worth.
Old 03-29-2009, 07:38 PM
It comes down to what you have for a transfer case.
If you have a 3-button dash switch, then it is possible to flat tow the truck. You will have to disconnect the rear driveshaft prior to flat towing it.
If you have the 4-button dash switch... I think you may be able to flat tow it, but you have to make absolutely sure that the front driveshaft does not turn as you move the vehicle along with disconnecting the rear driveshaft.
Closed Thread
Thread Thread Starter Forum Replies Last Post
Flat Towing a 2001 S10 4X4 gawilcox Steering, Suspension & Drivetrain 2 11-08-2013 10:12 AM
Flat towing the Jimmy with the Trailblazer? ComputerNerdBD 2nd Gen S-series (1995-2005) Tech 4 10-24-2013 12:09 PM
Blazer Flat Towing 4x4, Can It Be Done??? Dube2 General Chat 3 07-26-2013 01:55 PM
Flat towing a S10 Blazer Russ T Nut General Chat 3 12-07-2011 08:05 PM
Towing w/ 1998 Blazer 4wd LS Cecil 2nd Gen S-series (1995-2005) Tech 4 09-20-2009 10:03 PM
Tags
1998, bar, blazer, chevy, dinghy, drive, flat, ground, k5, mount, problem, tow, towable, towed, towing, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
