Fog light/ blinker combo Q's
My 98 blazer has an interesting setup. Luckily I noticed it before I ordered new lights for it:
Its sort of a fog light and a blinker combination? If I order, say these, will the wiring be okay? Am I going to have to change anything? Can I just remove the original turn signal and fog light? I want to get rid of the originals and put the listed item there instead. Will it function completely? I don't care about losing fog lights. Real men don't need em.
What you currently have is the standard set up for a 2nd gen Blazer with fog lights. The one you are looking at should fit your truck. You will simply have one bulb in it, right in the middle and would not plug in the connector for your present fog lights. I don't know the law in your State, but in Texas they would not be legal since they do not have an orange side reflector.
Is there actually a fog light there? Or is it just for looks?
Hell, I want those! I didn't even realize there was an option like that!
Those are what i had factory and its attached and comes out as one part just like the aftermarkets go in as one part. I changed my signals to a led set and bought headlights with halo's and used my factory foglight wiring to turn the halo's on the headlights on/off. It worked perfect . So ya short answer they are interchangable with any aftermarket signal lights.
Thanks for the response guys. Solved my problem. I am probably going to get the LED bumpers with the halo headlights.. 225 shipped! Wohoo.
blazintexas
05-01-2012 06:01 AM
jameskline5012
10-23-2007 10:07 AM
