grill and lights ole to new
i have a 97 with the 2 square lights and was wondering what i have to do change over to the newer lights. as new as i can get in. do i need the rad support? please as much info as possible.......i wud like to put the billet in also maybe later.
RE: grill and lights ole to new
Thet have kits available for that. But its way cheaper to buy a radiator support, headlights from a 98+ blazer, and grill. If you just buy the parts seperate you could just do it the way you want to, you can just buy the newer core support, then buy maybe halo's and a billet grill, but its all up to you on the look your going for.
would i be able to put H.I.Ds in those headlights or should i go for newer ones? and jus to make a checklist rad support, grill, lights(turn signals and headlights). all the wiring stays the same? and thanks for the info so far
Yeah I believe so on the HID's for the halo's, and yeah for the regular newer style lights. The bulbs shoulb be good if not you might have to get newer ones with the newer connectors, but you do need to get more slack out of the bumper turns on the 95-97 to go to the turns of the newer lights you will be putting on. And the checklist you made sounds good.
mudpony80
03-07-2010 02:53 PM
Mistermuffins
11-27-2009 05:21 PM
