nuts, line fitting @ front brake swap
Old 06-16-2014, 10:51 PM
chevyblazer's Avatar
chevyblazer is an unknown quantity at this point
Default nuts, line fitting @ front brake swap
i swapped my 95 single piston brake to 98+ dual piston brake setup; with knuckle, wheel bearing, caliper, bracket, ABS module and a good number of other hardware replaced; everything works fine.
Except for the front brake line, just couldn't connect..., i keep the old 95 model year front brake line tubing there, with the old nuts on both ends, coz they are same as the 98+ new models.
On the right side, the tubing's nut can't fit in the right front brake hose(newly bought 98+ front brake hose); and on the left side, the tube is connected to a 7/16 24 fitting, but this fitting doesn't fit in the new brake pipe from ABS module...
anything wrong with them? anyone would give me a hand???
Old 06-19-2014, 09:26 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
98 is metric brake line
Old 06-20-2014, 12:32 PM
abig84's Avatar
the fittings that go into the abs boxes are always some goofy size that is hard to locate at a local parts store. ive always just cut the line a little bit back off the abs line, put a new standard fitting on it and just reflare that end. if the line goign to the abs is rotted then just re use the old fitting
Xavier
04-11-2014 11:49 AM
wisowebs
12-26-2013 06:58 PM
bigjon720
04-01-2011 07:17 PM
NYC86ZC
12-12-2010 08:21 AM
ChevyFamily
07-10-2009 06:41 PM
Quick Reply: nuts, line fitting @ front brake swap
