Pulling Motor the Smart Way
Old 01-19-2017, 06:18 PM
zs_v8jimmy's Avatar
zs_v8jimmy is on a distinguished road
Default Pulling Motor the Smart Way
I plan to pull the motor next weekend to replace it with another 4.3L CPI I found around here for $400 running with all accessories. Main thing I'm trying to figure out is what would be the most simple way to pull it? Should I remove the bellhouse front bolts by using a few extensions and separating the engine block from the bellhousing, or should I just detach the driveshafts, pull the transfer case and pull both engine and transmission out at the same time? Just need to replace the motor AFAIK
It's my first time ever pulling a motor so I'm looking to get it done the most efficient way. Haha
Old 01-19-2017, 06:27 PM
rexmburns's Avatar
Super Moderator
rexmburns has a spectacular aura aboutrexmburns has a spectacular aura aboutrexmburns has a spectacular aura about
Pull the motor and trans together for sure especially since you already have the front end off. You will hate yourself if you don't after trying to get at the top bell housing bolts to remove them and even more when its time to put it back together.
Old 01-21-2017, 01:47 PM
zs_v8jimmy's Avatar
Sounds like a plan, thanks for your help!
Thor_449
04-21-2011 09:23 AM
fargoben67
11-16-2009 09:47 PM
kiwiblazer
09-14-2009 01:39 AM
ggwash21
Engine & Internal
06-17-2006 02:08 AM
BLAZER98
11-28-2005 11:48 AM
Quick Reply: Pulling Motor the Smart Way
