Radiator flush?? - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 09-13-2011, 07:29 PM
onenonlyme23 is on a distinguished road
Default Radiator flush??
i have a 99 blazer just did a flush and my radiator will not take no more than half a jug of anti freeze help!!! please
Old 09-13-2011, 07:56 PM
You completely drained the system and can now only get 1 gallon of coolant in?
Old 06-15-2012, 01:53 PM
spotteddog is on a distinguished road
I have had the same problem on my 96 4.3l blazer. Could it be that the water does not drain out of the block through the bottom hose possibly because of the thermostat being closed on a cooled engine and causing a siphon or finger on the end of a straw effect? I am going to test this right now by letting the engine warm back up and this time not letting the engine cool down as much.
---------------------------------------------------------------------------------- EDIT ----------------------------------------------------------------------------------
The temp I measured with an IR temp probe at the thermostat was showing 148 degrees and 129 degrees at the filler cap. I think the thermostat is around 150 so I maybe let it cool to much again. I did get more of the water out of it I think. Between the wifes insistance to get finished and running out of containers for the dirty fluid I seem to have lost control of the experiment. Any one who has an answer to draining a 96 Blazer 4.3l please post it.
Last edited by rriddle3; 06-15-2012 at 07:12 PM. Reason: Combining consecutive posts
Old 06-16-2012, 12:19 AM
How do you flush without removing the thermostat??? No wonder your having problems. most likely the thermostat is 190 degree.
Closed Thread
Thread Thread Starter Forum Replies Last Post
To flush or not to flush hroofblaze96 2nd Gen S-series (1995-2005) Tech 5 12-27-2012 08:33 AM
Aftermarket bumpers - flush and non flush, trim pfsantos 1st Gen S-series (1983-1994) Tech 3 09-23-2010 04:58 PM
Whats a good brand radiator flush or radiator cleaner to use? bigdaddykane93 2nd Gen S-series (1995-2005) Tech 6 01-04-2010 01:03 PM
coolant flush with flush kit portcqb 2nd Gen S-series (1995-2005) Tech 2 04-29-2008 10:56 AM
Power Steering Flush & Brake Flush ? ZR 2 2nd Gen S-series (1995-2005) Tech 2 12-04-2007 04:53 AM
Tags
05, 96, 99, blazer, chevy, chvy, cost, flush, flushing, forum, radiator, raeiator, start, with
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
