two issues with my 98 blazer Lt
I don't have the owners manual and was wondering how to reset the overhead Information Center
and number two I have no heat when the truck is warm and you shut it off and start it up again it will blow heat for about 3 seconds and then you can hear the door I want to say close on it blowing cold air immediately Weber had this vehicle before me install an aftermarket radio just wondering if something got crossed when they did this any suggestions??
its good and cold here in Wisconsin and with a 1 hour drive to work at 3 a.m. it gets pretty cold
Manual HVAC or Automatic Climate Control? The temperature blend door actuator is all electronic on both systems, so the diagnosis procedures are different. Broken gears in the actuator is a fairly common problem on both systems.
Rusto92
36
09-23-2012 09:07 PM
behemoth
05-18-2010 08:53 PM
parttimer
10-10-2008 12:28 PM
