General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
a/c works after about 10 minutes
Old 08-22-2006, 11:39 AM
mattphillips4's Avatar
mattphillips4 is an unknown quantity at this point
Default a/c works after about 10 minutes
My A/c takes about 10 minutes at the start of each day to come on. Once it comes on it works fine the rest of the day. I have jumped out the low pressure switch and it still does nothing. Then wait about 10mins and it comes on. Any ideas?? 97 blazer
Thanks
Old 08-22-2006, 11:43 AM
flowmasta's Avatar
flowmasta is an unknown quantity at this point
Default RE: a/c works after about 10 minutes
ok a/c is not my specialty considering mine hasnt worked in over a year, but it usually takes a little while for the a/c to really start working in any car but 10 minutes does seem a little longer than normal.....when it does start working how cool is the air?(does it work great or just blow out kinda cool air)
Old 08-22-2006, 11:46 AM
it takes 10minutes for the compressor to come one, then it is very cool
Old 08-22-2006, 12:21 PM
guywm25's Avatar
guywm25 is an unknown quantity at this point
do you ever here the clutch kick on all the time?
I you do it is low on coolant
Old 08-22-2006, 12:26 PM
it's not low because I can jump out the low pressure switch and it still doesnt come on
Old 08-22-2006, 04:25 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Check your cooling fan clutch sounds like you may have a HIGH pressure issue.
terryst
06-20-2014 03:49 PM
Blazin-95
12-29-2012 09:25 PM
pacojimenez
07-28-2011 05:07 PM
herbanfarmer
06-12-2011 10:55 AM
adhdandthensome
02-27-2011 08:07 PM
Quick Reply: a/c works after about 10 minutes
