General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Automatic Transfer Case Fluid (GM Part No. 12378396) - what is?
Old 10-14-2006, 01:28 PM
Marcin's Avatar
Marcin is an unknown quantity at this point
Default Automatic Transfer Case Fluid (GM Part No. 12378396) - what is?
Hi
I would like to change all fluids in my car and I find something lika this in my manual: Automatic Transfer Case Fluid (GM Part No. 12378396). What is it? Do you know any equivalent fluid?
Regards, Marcin
Old 10-14-2006, 02:03 PM
Default RE: Automatic Transfer Case Fluid (GM Part No. 12378396) - what is?
It's pretty self explanitory... It's Automatic Transfer Case fluid... It has an additive for those transfer cases which allow for automatic engagement of the 4wd (NVG 233 - NP1 or NVG 136 - NP4). So if you do not have the auto 4wd option (NVG 236), you can just use the same ATF fluid as used in your transmission although GM recommends using the AutoTrak II fluid in all transfer cases. I am unaware of any alternative to it, but its not like the stuff is wickedly expensive.
Old 10-14-2006, 06:09 PM
Marcin's Avatar
I have no auto 4 wheels driven. My options are only 2HI, 4HI and 4LO, no 4AUTO. So in this way I should have an extra 2 liters of ATF Dexron III for my AT case if I understand.
Thanks!
Marcin
Flyfishen
06-18-2019 11:22 AM
kmartin
01-18-2014 07:49 PM
spider21
11-17-2011 06:27 PM
DaleA
01-13-2009 08:50 PM
kmartin
14
12-03-2008 12:48 PM
Quick Reply: Automatic Transfer Case Fluid (GM Part No. 12378396) - what is?
