General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
drivers side mirror fell off my 98 blazer
Old 10-18-2006, 11:19 PM
gmaltese's Avatar
gmaltese is an unknown quantity at this point
Default drivers side mirror fell off my 98 blazer
hello my 98 blazers out side mirror and all fell off, the only thing holding it on was the power and heat cable, i see them on ebay for about 23ish dollars
2 questions, first.... is ebay a good place to get my heated power side view mirrors?
and lastly HOW THE HELL do i get the door panel off to change the mirror?????
thanks glen
if any one has pics that will help
Old 10-19-2006, 01:09 AM
Chevy Lover's Avatar
Default RE: drivers side mirror fell off my 98 blazer
I've never used EBay, so I can't help you there.
Remove the inside door handle bezel.
Remove the power accessory switch mounting panel, Use a flat-bladed tool in order to carefully pry the cover up at the front leading edge. Disconnect the electrical connectors from the switch.
Remove the switches from the switch mounting panel, if necessary. Then slide the panel forward to remove.
Remove the trim panel armrest screws.
Use a wide, flat screwdriver ir a trim removal tool in order to release the door trim panel retainers.
Remove the door trim panel from the door.
Old 10-19-2006, 11:29 AM
irocknrol2 is an unknown quantity at this point
Ebay can be all right to get parts from. Just be cautious and do some homework on the person and/or company selling the products. There have been some fraud cases out there.
Old 10-19-2006, 11:30 AM
Brian J. Lesko's Avatar
Brian J. Lesko is an unknown quantity at this point
I broke the mirror off my Sonoma a while back. It wasn't power, so I got a brand new one from Summit Racing for around $45. It was a direct factory replacement. They had the power/heated ones available too, but I didn't check prices. That might be a way to go if you are concerned about buying something from Ebay. That way you can be sure that nothing will be wrong with it, as it will be a brand new part.
scphill34
03-10-2013 03:59 PM
LVUSC14
06-13-2012 05:58 PM
jakegaisser
04-06-2011 11:35 PM
MintyMadness
04-23-2010 09:43 AM
danzy55
02-28-2009 12:36 PM
Quick Reply: drivers side mirror fell off my 98 blazer
