2002 Chevy Trailblazer - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 08-11-2007, 03:06 PM
betsihook is an unknown quantity at this point
Default 2002 Chevy Trailblazer
I just had a front headlight go out so I replaced it. When I first put it in both lights worked fine, now my low beams don't work at all. I checked the fuses and everything is ok, any suggestions??
Very frustrating!!
Old 08-12-2007, 01:59 PM
Default RE: 2002 Chevy Trailblazer
Fuses 3 & 6 (10A) in the underhood fuse block should be the left and righ headlamp fuses, respectively. The other things that the headlights have in common are their voltage feed through the HDM Relay in the underhood fuse block. This relay supplies power to the low beams for DRL and normal headlight functions.
Old 08-21-2007, 01:57 PM
*Moving to Gen Tech - GMT360 Tech*
Any updates on your problem? Do you need additional information?
Closed Thread
Thread Thread Starter Forum Replies Last Post
2002 Chevy Trailblazer part question FBH1992 GMT 360/370 Tech 2 01-14-2012 11:45 PM
a couple 2002 trailblazer speaker questions jrpx2 Audio/Video Electronics 6 07-08-2010 02:02 PM
2002 trailblazer dome lights mboggess 2nd Gen S-series (1995-2005) Tech 5 07-16-2008 09:00 PM
2002 Trailblazer Front Bumper..Need Help!! lionel2 GMT 360/370 Tech 2 02-23-2008 07:25 PM
2002 Trailblazer brian101798 GMT 360/370 Tech 7 01-11-2008 10:46 AM
Tags
2002, blazer, block, chevy, chevytrailblazerforums, forum, forums, fuse, headlamp, headlights, power, problems, relay, trailblazer, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
