TrailBlazer GMT360/GMT370 (2002-2009) Tech Have a 2002-2009 Trailblazer, Envoy, Bravada or Rainier? Post your general tech questions here.
defroster setting causing stalling
Old 04-04-2008, 08:05 PM
dlew133's Avatar
dlew133 is an unknown quantity at this point
Default defroster setting causing stalling
I was at a stop light and change the air flow from the heater from the floor to the defroster. The RPM's started to drop and the car felt like it was going to stall. I returned the air flow toward the floor and the problem was gone.
I experimented with it and found that every time I set the air flow toward the defroster, the car felt like it was going to stall. The other settings were ok.
Any ideas what could be causing the problem?
Old 04-04-2008, 08:16 PM
Default RE: defroster setting causing stalling
My bet would be on a vacuum leak in the dash either the HVAC control head has an internal leak, the vacuum line to the mode actuator is broken, or the mode actuator itself is faulty. Looks like you need to open up the dash and see what's going on inside.
Old 04-04-2008, 08:47 PM
dlew133's Avatar
Do you think this will be a difficult project. A while ago I heard that replacing the actuator was quite an effort. I don't want to get into to this and find I would have been better off taking to the shop.
Old 04-04-2008, 08:58 PM
Do you have auto climate control or manual?
Old 04-04-2008, 09:09 PM
dlew133's Avatar
Manual
hillbillyinOhio
07-08-2011 09:28 AM
jojocarreno
05-27-2011 12:27 PM
blazinDJ420
06-18-2010 10:21 AM
89K5
12-15-2007 03:29 PM
nofear17bmx
01-16-2007 12:51 AM
Quick Reply: defroster setting causing stalling
