Cat back
Cat back
Im trying to get ideas 2 redesign my blazer and im looking for a cat back system that 1 boost tons of hp and is loud and 2 it must me a dual or single rear exiting exhaust, i have yet to find a good one here are some specs of my vehicle incase u know of any
2002
Blazer LS
2wd
2door
5speed
4.3L 190hp
im trying to get up to 300 hp at least so any suggestions there will help also
2002
Blazer LS
2wd
2door
5speed
4.3L 190hp
RE: Cat back
easiest way to get 300hp is forced induction (ie. supercharger, turbo) and everything will be costy to get your engine there the other way is a whole lot of engine work (internals)
single cat back from gibson for your blazer.... CLICK
I only searched on truckperformance.com so you should be able to find some other systems... good luck
RE: Cat back
Yes Gibsons are nice but it looks to be a side exiting, and im weird and like them out the back so if u happen to see any other ones please post them
Thanks,
Kevin
Thanks,
Kevin
RE: Cat back
No way your going to go from 190hp to 300hp with just a exhaust system. you'll have to throw on some stickers too.
Check with your local muffler shop. They should be able to install an exhaust system to suit oyur needs. Basically you just need a different tailpipe, or whack off the factory unit and put on a straight pipe to dump out back.
RE: Cat back
the only way that you can get 110hp from an exhaust system, is if that exhaust system has a turbine and compressor wheel in it...
RE: Cat back
never said i was getting 300hp from an exhaust system i want one that will boost it 5hp i just happend 2 put that to see if anyone has any suggestions for any upgrades and what not
Squad-6
Headers, Intake, & Exhaust
05-17-2011 10:29 PM
djbass_mekanik
04-22-2006 06:15 AM
