2-3 inch front suspension lift
Old 08-04-2011, 02:15 PM
FirePhage's Avatar
FirePhage is on a distinguished road
Default 2-3 inch front suspension lift
Been reading the tutorials here, and still haven got the answers im lookin for, so I'll just ask... I want to put 32" rubber under my 97 4dr 4wd. Planning a 2 inch body lift, and a shackle flip on the rear. that oughta gimme enough room in the back, but I'm still having a hard time with the front end. I know a t-bar lift should give me close to the needed room, but I just dont like the idea of such a mod messing up my cv joints and such. So my question is, what would be the most efficient (read cost effective lol) way to raise the nose of my trucks front suspension up 2 to 3 inches?
Thanks!
Old 08-04-2011, 03:31 PM
mdehoogh's Avatar
The only way to lift the front is by lowering the front axle. You can,
A) Lower the entire axle with the 5" or 6" kits (Superlift, Trailmaster, BDS) or,
B) Lower the control-arms/wheel-hubs via torsion bar crank
Neither option is ideal, A is expensive and B can have long term effects with steeper steering/CV/balljoint angles.
Unfortunately, those are the only two options (short of doing custom work)
Old 11-21-2011, 11:33 PM
oldsbravada2000's Avatar
oldsbravada2000 is on a distinguished road
Rough Country makes a 2.5 inch lift with a differential drop. They just redesigned it and it is no more than $500 or $600 and will give you what you need.
Chevy / GMC Suspension Lift
Old 11-22-2011, 03:43 PM
FirePhage's Avatar
Excuse me while I drool ad thank you at the same time! This is just what I was looking for, and you provided it just in time for christmas! i do love this forum!
Old 11-22-2011, 06:10 PM
xgiovannix12's Avatar
there having problems with the new rough country lift id contact them before buying it
make sure they fixed all the bugs
Old 11-23-2011, 09:05 PM
FirePhage's Avatar
Figures it'd be too good to be true! lmao Thanks for the headds up, XG!
Old 11-27-2011, 12:21 PM
twisteds10blazer's Avatar
twisteds10blazer is on a distinguished road
They were having a problem with therough country ballpoints but they told me they fixed it per new orders and sent those with the lift already they sent the proper parts. Mine is in the mail I've been tidings just a tbar crank for 2like yrs just found out y I was goin thru cvs and hubs but now thanks to this forum um good to go now thanks everyone
Old 02-19-2012, 08:23 AM
stensg's Avatar
stensg is on a distinguished road
Do you need springs with this kit or does it use stock? And should I regear with this lift and 31s?
Old 02-19-2012, 02:05 PM
war00's Avatar
war00 is on a distinguished road
with a body lift and the rough country lift you can clear 32's no problem. just make sure that when you install the lift that you put it to the 21" ride height that they get recommend or you will run into problems with your cv's.
Old 02-19-2012, 11:57 PM
j89lumaye's Avatar
j89lumaye is on a distinguished road
We dont have springs in a 4x4, just torsion bars and shocks
BackwoodsBogger14
Lifting Tech
03-26-2014 08:45 PM
Keeler
Lifting Tech
22
05-29-2010 03:53 AM
blazinUP
Tires and Wheels
05-14-2010 08:06 PM
third2121
Suspension Tech
07-25-2005 02:23 PM
Quick Reply: 2-3 inch front suspension lift
