Spring over conversion
Old 02-28-2010, 08:54 PM
Farmboy92's Avatar
Farmboy92 is on a distinguished road
Default Spring over conversion
I was just wonderin..I got a 95 blazer 2 door 4x4, if you were to do a spring over conversion in the rear, itd add a couple inches of lift, how would you level out the front? bigger coils and longer shocks or somethin? Its got me curious
Old 02-28-2010, 08:58 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
an SOA conversion will give you between 3-4" of lift in the rear. There is no way to match that on the front. Just get a 6" suspension lift. Your blazer does not have coils in the front so spacers are out of the question.
Old 02-28-2010, 10:37 PM
NVANZEE's Avatar
its actually lifts it about 5in after you weld on a new spring perch. The highest you can lift the front it 1.5-2in
Old 03-01-2010, 12:28 PM
Farmboy92's Avatar
wow i feel like a dumbass lol. i completely forgot it didnt have coils. oh well, did a torsion bar and shackle lift and that should be enough for now. but damn them 6 inch lifts are pricey lol.
luckyferg1313
Lifting Tech
04-21-2010 09:47 PM
Maxflyguy92
Lifting Tech
10-19-2009 10:38 PM
M. Lowes
Lifting Tech
07-23-2009 12:05 PM
harpnicholas
Lifting Tech
05-14-2009 08:50 PM
remery
Lifting Tech
06-02-2008 08:08 AM
Quick Reply: Spring over conversion
