START HERE - lift kit list
Old 01-15-2015, 10:51 AM
El_Beautor's Avatar
Originally Posted by dhud64
So, a 3" body lift is the maximum for a 99 TB, is that correct?
As far as I know there isn't a 3" body lift kit sold for the 2nd gen Blazers. Lots of people have successfully adapted the 1st gen 3" kit onto the 2nd gen Blazers though. Anything bigger than that will probably involve a lot of custom work and fabrication.
  #212
Old 06-10-2015, 04:23 AM
Bolbol's Avatar
Bolbol is on a distinguished road
Any experience with the 6 inch RC lift?
Seems cheap but doesn't sound bad. Worth?
  #213
Old 06-10-2015, 05:47 AM
newguy's Avatar
^ inch lift is a decent kit, would recommend some low backspacing rims and at 10.5 tires to increase stability. Need a wider stance
  #214
Old 10-28-2015, 06:35 PM
keegs35's Avatar
keegs35 is on a distinguished road
Default New to suspension mods
So, I have a 2000 Blazer LT, 4-door, 4 wheel drive. I am looking to put a 2 inch lift on it and upgrade the suspension, but honestly have no idea where to start, what I need to make sure is compatible between the lift kit and the suspension parts (shocks, struts, etc.). My blazer is riding a little harder so i do know the suspension needs to be upgraded.
Just looking for direction of where to get started or where to learn what I need to before getting underneath the truck.
Also good brands and parts that people have tried.
I am also trying to do this rather inexpensively but don't want to buy something that isnt quality, just looking for that happy middle ground of quality and cost.
  #215
Old 02-07-2016, 08:53 PM
Eloi Brouillard's Avatar
Eloi Brouillard is on a distinguished road
Exclamation Info Needed
hey guys my names eloi im new to the blazer fourms and am looking for advice i just git a 01 blazer ls and am looking for a lift kit preferbly 6in lift kit dose any one know if any of those kits are compatible with the 2 door blazer? all the help is appreciated
thanks
  #216
Old 02-08-2016, 10:46 AM
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
Not that I can think of. Your best combination for the money is a 2" body lift and 2.5" rough country lift. That should get you to 31's
  #217
Old 11-20-2016, 10:13 PM
Brian K. Balzer's Avatar
Brian K. Balzer is on a distinguished road
I'm wondering what the bare minimum is that has to be done when doing 3" lifting keys and shackles and possibly 2" body lift on an old 85 Chevy S10 4x4 Blazer. My son is wanting to get just enough room to run my friend's 31's and as most of you probably know they hit on the back side of the wheel well.
I've researched changing the torsion keys - easy enough - and I know how to change the rear shackles - also easy enough - but I'm wondering what else Has to be done after doing those.
I'm also curious why it seems common to see 1-3" torsion keys sold with 2" shackles. Am I mistaken or does that actually only give you the choice of going up 2"? (I've always been under the impression that a 4x4 should be level.)
  #218
Old 11-21-2016, 10:06 AM
95teal4x4's Avatar
95teal4x4 is on a distinguished road
i think something else you may want to look into is shock extenders. i am by no means an expert on lifting but i have done my research. they extend the length of your shocks without extending your shock travel so they aren't maxing out their travel when going over bumps.
As for 1"-3" torsion keys, they are almost no different than your factory keys except that their angle is slightly different. they allow you to crank them over the factory keys amount. so really you don't really need to swap them if you plan on doing a 2" lift. Anyways that is my understanding of it.
  #219
Old 11-21-2016, 03:28 PM
TMM217's Avatar
TMM217 is on a distinguished road
I would think the 1"-3" keys will let you level the truck. Front usually sits lower than rear from the factory.
  #220
Old 11-21-2016, 10:06 PM
Default Shock extenders
Thanks for the input. I'd thought about those as well but according to some of the people I've been talking to it would also require the brake lines, filler neck, and steering column to be lengthened.
At this point I'm not sure it would be practical to try to lift it. Still weighing the options though.
Quick Reply: START HERE - lift kit list
