1998 Blazer Power Seat fix - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 10-04-2011, 11:53 AM
AndrewRSmall@Hotmail.com is on a distinguished road
Default 1998 Blazer Power Seat fix
I just fixed the seat on my 98 Blazer. Thanks to everyone who have posted fixes on this site because it has saved me a lot of time and trouble. I had a problem with my power seat (driver side) which was intermittent. When the seat wasn't working it would drain the battery so something was shorting. The wiring under the carpet turned out to be fine but. The problem turned out to be the wire bundle between the seat position switch and the motors was being squashed between the the seat bottom and a metal part of the seat base when the seat was all the way lowered. There was a wire in that bundle that had insulation worn away and was grounding to the metal seat base. I think this was caused by the fact that a couple of the steel wires under the seat that support the foam were broken letting the seat sag a bit. I sealed up the wire with electrical tape so that should fix it for a while. I'll fix the seat support as well at some time.
Closed Thread
Thread Thread Starter Forum Replies Last Post
1998 Power Seat Stopped Working sportjunkee Lighting & Electrical 7 08-25-2015 12:59 PM
Frame rot, To fix or not to fix r_marczak_83 Full Size K5 Tech 17 03-09-2013 11:33 AM
Power seat has no power. TrTl Lighting & Electrical 6 09-22-2012 10:56 AM
To fix or not to fix. Dodge Guy General Tech Help 4 10-25-2006 09:48 AM
Tags
1998, 98, blazer, broke, chevy, common, electric, fix, front, power, problems, sagging, seat, seats, switches, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
