short draining the battery
Old 01-08-2017, 04:42 PM
daviddodge's Avatar
daviddodge is on a distinguished road
Default short draining the battery
I have a 1990 s10 Blazer with a short we have id the circuit and it is on the fuse marked horn/dm how do I get a electrical diagram and then track it down. please help
Old 01-08-2017, 05:02 PM
Rusty Nuts's Avatar
There's a light in the glove compartment tied into the dome light circuit that could stay on and drain the battery if the switch on the door is broken. Pull the glove box light bulb and see if the drain goes away.
Old 01-08-2017, 05:49 PM
daviddodge's Avatar
Mr nuts (my son thought that would be funny) you were correct the glove box was broken around the time this started we had a .26 drain on th bat . with the bulb out it droped to .01 which we will se if that's ok. so thank you very much.
Old 01-08-2017, 06:13 PM
Rusty Nuts's Avatar
Very welcome, your son is right . Anything .05 and under is acceptable.
tmay2
01-15-2010 08:52 PM
tnw912
01-05-2010 05:27 PM
brightside
12-16-2009 10:50 AM
kiwiblazer
10-21-2008 01:14 PM
BradN10
07-22-2006 10:58 PM
Quick Reply: short draining the battery
