ABS/Parking Brake Dash Light Will Not Turn Off
OK..I probably out smarted myself. ABS light came on and would not go out. I realize it's probably a sensor and was going to remove the sensors and clean the tone ring(?) and sensor when I get time and if that fixed it, order the parts and repalce them. BUT for now for a quick fix (work 12 hour days), I pulled the ABS blub out of the dash just to try to shut it off till I can really work on this thing. Well, after the bulb was out, the ABS/Parking brake light came on and will not go off. WHAT TRIGGERED THAT???. It wasn't on before ??? I put a bulb back in the ABS on the dash but the ABS/Parking light still didn't go off. The ABS is useless on this truck anyway so i could care less to disable it but I have to get the lights out for inspection. Anyone have any idea why the light came on and how to fix it? The truck is a 1995 4x4 Blazer.
Yea my ABS unit doesn't work on my 95 So i disconnected the power to it, and re wrapped the wires, Passed inspection and everything. Apparently from what i've heard, the units on blazers are famous for going bad? Middle plug, Cut the green wire, The light will go out. and it will pass inspection.
allysheedy67
01-14-2014 05:08 PM
gturzer
03-25-2013 05:00 PM
Kralph42
10-01-2010 12:55 PM
beastbandit92
08-13-2010 08:24 PM
cide
08-09-2009 08:02 AM
