blower motor
blower motor
the heater/AC blower motor on my 95 blazer doesnt seam to blow very hard.When you turn the blower switch to high the blower stops.I have replaced the switch and the motor restaer looks like it is the blower itself has anyone ran into to this.I thought the blower worked or it didnt.Never see one go from low med to I thank High then off
The problem is NOT the motor.
Ignition in the RUN position, mode switch in the HEAT position, blower switch in the HIGH position. Disconnect the electrical connector from the blower relay.
In the vehicle harness connector that you just unplugged:
The orange wire and the red wire must both show battery voltage.
Post your results.
Post your results.
maxvamp
10-31-2020 08:19 AM
SWATPARAMEDIC
01-01-2010 03:12 PM
highlife756
11-16-2009 03:57 PM
