Brake Light on Dash ??
Old 06-05-2011, 08:18 PM
Don Green's Avatar
Don Green is on a distinguished road
Default Brake Light on Dash ??
Anyone else having trouble with the brake light coming on the dash? It flashes sometimes, it stays on sometimes, sometimes doesn't.
01 Blazer.
Old 06-06-2011, 07:33 PM
abig84's Avatar
start with the basics, make sure the brake fluid is full, the emergency brake is fully disengaged and there are no leaks
Old 06-06-2011, 07:54 PM
tornado_735's Avatar
tornado_735 is on a distinguished road
On my '98 Blazer, I'm having an issue with my brake pedal having a LOT of travel, and the brake light being on. Fluid level is good, etc.
Because of some experiences I've had with GM ABS, I pulled the ABS fuse in both fuse blocks. The Brake light in my dash went out, and the ABS light came on.
Try pulling the ABS fuse on the inside fuseblock, and see if the brake warning light goes out. If it does, there might be some issues with the ABS pump. I'm thinking there is with mine.
Old 06-06-2011, 07:58 PM
96jimmyslt4x4's Avatar
96jimmyslt4x4 is on a distinguished road
Take a video.
Old 06-19-2011, 01:38 PM
gmc004x4's Avatar
gmc004x4 is on a distinguished road
i have a 2000 had to replace the rear hard line on the pass. side. about a week later the abs light came on. i do not think the line has anything to do with it. unless the light will come on if there is still a little air in there. does any one know excatly where the speed sensor on the transfer case is located? how hard is it to replace and can i get to it while i have it on jack stands?
Doggpool
05-24-2011 08:17 PM
frankmackie
03-08-2007 08:46 PM
Daninehnj
02-22-2007 02:26 AM
lylebig
01-30-2007 04:42 PM
Quick Reply: Brake Light on Dash ??
