Dead Battery, Gauge Problem
For the last month, I have had to jump my Blaze off 3 times due to a dead battery. But AAA tells me the battery test is inconclusive. Charge and retest.
For the last couple of weeks, I have not driven my Blaze. I got in it this morning and the battery was completely dead. Not even the normal click. AAA came out, and the battery was under 3 volts. They jumped it off again and advised me to drive it for at least an hour. When I got in, the fuel gauge read low, and the low fuel light was on, the security light was on as were the abs and brake warning lights. The charge gauge reads 14 volts pretty constantly.
I filled up the tank just to make sure I had gas and ran it for about an hour with the warning lights on. When I turned it off, the security light stayed on.
Does anyone have any idea. It's an 04 Blazer, 4 door, 2wd. Stock except for an aftermarket head unit. No amps, etc.
I cant really help with the situation as I do not know these second gens at all very well.
One thing I can help you with is the reading the dash gauge is giving you, that is giving you a voltage reading and not an amperage. So when it is saying 14, it is actually 14v.
"Inconclusive" is not a test result I want from a battery. How old is it? After needing 4 jumps I would replace it. Did this start after the head unit was installed? It's either a bad battery or something draining it.
Thanks. Battery is just under 3 years. Has 3 yr non prorated battery. Head unit is over 4 years old. Would a dead battery cause the fuel Guage and safety lights to act up
with the lights I don't know for sure but that's my bet - if the battery is dead and maybe has a bad cell or in the process of shorting out I would think all the charging amps and volts would be trying to recharge the battery and not feeding enough to the rest of the vehicle systems - I would take it in and have it checked just in case - cooler temps are here and that's usually when a dieing battery will leave you afoot - I see your down south - here in Wyoming it's 4 above zero here tonight darn cold
[QUOTE=odat;657590]with the lights I don't know for sure but that's my bet - if the battery is dead and maybe has a bad cell or in the process of shorting out I would think all the charging amps and volts would be trying to recharge the battery and not feeding enough to the rest of the vehicle systems - I would take it in and have it checked just in case - cooler temps are here and that's usually when a dieing battery will leave you afoot - I see your down south - here in Wyoming it's 4 above zero here tonight darn cold[/QUOTE
Taking it in tomorrow am. Actually later today.
Took her to a real mechanic. Battery was beyond bad. They fully charged it and it was dead 10 minutes later. I asked them to check for phantom draw. No problems found. I feel like I got my baby back. Thanks for everything guys
N0SL3N
11-12-2014 08:52 PM
94s10blazin
08-10-2013 01:00 PM
