short draining the battery
There's a light in the glove compartment tied into the dome light circuit that could stay on and drain the battery if the switch on the door is broken. Pull the glove box light bulb and see if the drain goes away.
Mr nuts (my son thought that would be funny) you were correct the glove box was broken around the time this started we had a .26 drain on th bat . with the bulb out it droped to .01 which we will se if that's ok. so thank you very much.
tnw912
01-05-2010 05:27 PM
brightside
12-16-2009 10:50 AM
