Dome Light Override and DRL Cut-Off
Old 12-14-2016, 07:08 AM
ekaye1's Avatar
ekaye1 is on a distinguished road
Default Dome Light Override and DRL Cut-Off
Hi all
I'm very new here (today)
My Blazer has no override for the dome light. It's driving me nuts. I am not finding answers to many of my questions on UTube because there seems to be many differences in what is under the dash from my 96 chevy blazer 4X4.
I managed to find and "cut-to-insert-switch" the wire in my 88 Mustang GT but caused a lot of issues with the fog lights and headlights. I would rather not repeat that on my Blazer.
I have been under the dash looking for the DRL module (no luck) and the dimmer wiring for the quad headlight/HiBeam mod. My probe is just not sharp enough to find the right two wires among the other 50.
Any advice on the dome light or other mods would be GREATLY appreciated.
Old 12-14-2016, 09:24 AM
blazen_red_4x4 is on a distinguished road
Pretty sure 94-97 did not have the override options
there is no DRL module in these, it's built into the BCM unfortunately (makes the DTR a biotch to disable in the S-series...)
Old 12-14-2016, 10:14 PM
ekaye1's Avatar
Thank you blazen_red_4x4
I was hoping someone here knew about an easy way to kill the dome/courtesy lights without chopping into the harness [or cutting and inserting a kill switch to just the "ONE" right wire). I found a big pile of schematics online but not specific to my 4x4 so no chopping - yet.
The DRL module is definitely not present but the fuse panel to the left of instrument cluster has #15 / 10 amp fuse on what they call DRL / Fog lights (canada). Since no other destinations were shown, I pulled it and WALLAH !
No more DRLs and no apparent "side effects."
Old 12-15-2016, 08:08 AM
ah yeas I should have mentioned the fuse, sorry :P that's how I disabled the DRL on my father's 95 Sonoma
Old 12-16-2016, 11:34 PM
ekaye1's Avatar
Still stuck on the "quad headlight mod."
I saw a U-tube on tying the Low Beam "on wire" to the Hi Beam, dimmer switch wire on the column so that the Low Beams stayed on when the Low Beams were switched to Hi . This makes up for the loss of low beams when you really want MORE light.
Has anyone here done it?
Old 01-01-2017, 07:23 PM
DARK1's Avatar
DARK1 is on a distinguished road
I'm lookin for the same solution. Killing the dome would be as easy as putting a toggle switch on it but the same circuit is also the floor lights and rear tailgate light. When we go camping I have a tendency to leave doors and windows open for hours at a time. A dead battery would be bad 15 miles from the nearest paved road. I'm gonna subscribe to this thread in case a more knowledgeable member has already solved this one. Meantime I'm gonna look around utube and google. If I find an answer I will share it back here if it works OK
JoJo11
08-13-2013 04:57 PM
dano440
05-11-2012 06:57 PM
b1heqh54
14
05-09-2011 09:28 PM
Sisk
05-29-2009 10:27 PM
ltown21
07-18-2007 10:00 PM
Quick Reply: Dome Light Override and DRL Cut-Off
