Door alarm 2000 Blazer
Anyone Know how to stop the alarm every time I unlock the door till I start the engine? Dont need an alarm system. I changed the driver door lock and since then the annoying alarm. Thanks THere has to be a way without having to buy another door lock system with new switches.. Thanks
If this is the Factory Alarm:
You cannot Remove the Alarm, but can DisArm / DisAble it
Find the Light GREEN wire located in the Driver Kick Panel / Door Boot (harness that goes into the door), or at the BCM, located under Passenger Dash on the Heater Box
Wire located in B3 of Purple Plug
Ground the Light GREEN wire
yardbird
06-14-2019 05:54 PM
droidxusa
08-20-2012 08:16 PM
red02zr2
04-26-2010 06:08 PM
