Timing issue
Old 08-05-2011, 12:13 AM
lmorrow's Avatar
lmorrow is on a distinguished road
Default Timing issue
I replaced my intake gasket and now I can't my 2000 S10 blazer started. It is a 4.3L. I believe it is a timing issue. I followed these instructions
EDI Engine timing
and now it still won't run, but it is backfiring, so I think that is progress. Any ideas?
Old 08-05-2011, 07:11 AM
I'd say you need to follow the directions more closely. Sounds like you didn't get it timed correctly on your first attempt.
Old 08-06-2011, 10:23 PM
lmorrow's Avatar
You are correct.
I went back through the procedure again and noticed that the 6 for a 6 cylinder engine was designated by a small triangle with a 6 in it, and was also 180 degrees from the number 1 cylinder. Diagram 1 is for 6 cyl and 2 is for 8 cyl
Started on the first try.
Here is the link for anyone interested
https://blazerforum.com/forum/tech-a...-timing-24373/
Doctorvette
11-05-2012 11:57 PM
Denominator
09-23-2010 02:40 PM
hotrodln
17
04-26-2010 07:32 PM
Denominator
04-25-2010 06:31 PM
laurstevechar721
11-13-2008 02:48 PM
Quick Reply: Timing issue
