fuel pump fuse location - Blazer Forum - Chevy Blazer Forums
Search
Search
Closed Thread
LinkBack Thread Tools Search this Thread
Old 01-24-2011, 01:59 PM
rick e is on a distinguished road
Default fuel pump fuse location
Fuel pump has no power. fuse box doesn't list fuel pump. Which fuse is it?
Oh, it's a 1991 S-10 V-6.
Old 01-24-2011, 02:12 PM
Gimpy Blazer is on a distinguished road
Try the ECMB 15 amp fuse. Probably not the problem but at lrast I'll give you credit for starting in the right place. You can jump around the fuse safely. Let us know if it's not the fuse and I'll tell you how. Just don't have time right now to explain.
Old 01-24-2011, 02:35 PM
Need to jump around fuse safely. Checked ECBM and it's good. Thanks, I'm going to run
new wire from fuel pump to "Where"? Not sure where the relay is located or how to test.
Old 01-30-2011, 02:05 AM
There is a connectorin the vacinity of the blower resister on the right firewall and it goes straight to the fuel pump. The jumper wire should have a amp fuse in line and you can bypass all of your fuel pu,p wiring and hit the pump with 12volts to see if it's working. It's called the fuel pump prime connector and the wire is gray. You'll know it because nothing is hooked to it. Jump this with straight to the battery and you should hear the pump run. You might want to first make sure your fuel pump & sender grounds are OK. They come off the top of the tank and the wire is black in color. Forget therelay for now and just see if the pump runs. If it does there are two relays on the upper left side of the firewall. Just swap them and that will check the relay. Another way to see what's going on is to crank the engine until you get some oil pressure to check the oil pressure witch (which the pump circuit runs throigh) and the engine should start. I live for this stuff. By the way your pump wire runs off the ECNB fuse (15 amp) and you'll see it's an Orange wire into thee relay and gray coming out. From there it splits and one goes straight to the pump and the other goes to the fuel pump prime connection. If you're getting 55 - 61 psi it's the wrong pump. TBI engines only put out about 19 - 20 psi. You should have that. Any more and you're flooding the engine. If your gas guage works then the pump ground is probably OK since they share the same ground. What is the fuel pressure?
Closed Thread
Thread Thread Starter Forum Replies Last Post
ECM / PCM fuse location ??? 95 Blazer miztic2u 2nd Gen S-series (1995-2005) Tech 0 07-08-2012 08:21 PM
Location of ABS Fuse on 2001 chevy Blazer sdjames Steering, Suspension & Drivetrain 2 08-24-2011 04:13 PM
wire gauge & fuse location streblo Lighting & Electrical 5 04-02-2011 04:43 PM
AC compressor fuse location richiekeystone 2nd Gen S-series (1995-2005) Tech 3 08-19-2010 10:22 PM
96 Blazer Fuel Pump Fuse/Relay Location Poke626 2nd Gen S-series (1995-2005) Tech 1 07-02-2008 03:37 PM
Tags
1991, 1994, 94, blazer, chevy, fuel, fuse, gmc, jimmy, jumper, location, pump, s10, sierra, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
