how to remove the battery? - Blazer Forum - Chevy Blazer Forums
Closed Thread
Thread Tools Search this Thread
Old 12-29-2010, 12:02 AM
cahlersmeyer is on a distinguished road
Default how to remove the battery?
hello all,
new to the forum, but not new to forums.
i have a 2004 4DR 4x4 4.3L Blazer.
I need to replace the battery. How do I do so? I removed the connections easily enough, but could not lift the battery up and out. do i need to remove the bolt between the washer fluid tank and the battery to do so? thank you in advance?
pics would be great!!
-C
Old 12-29-2010, 01:14 AM
ABN31B's Avatar
there's a little tooth that holds the battery to the tray. a black plastic wedge looking guy i believe... sits on the tray on the firewall side i believe...
haven't moved mine in a minute though so i dont remember 100% :/
Old 12-29-2010, 02:00 AM
mdehoogh's Avatar
Super Moderator
yeah that bolt between the battery and coolant reservoir comes out and lets you remove the little black piece ABN31B mentioned.
Old 12-29-2010, 06:46 PM
ABN31B's Avatar
thanks for the assist mdehoogh.
looks like you wereon the right path from the get-go
Closed Thread
Thread Thread Starter Forum Replies Last Post
BATTERY CONNECTERS MELTED to BATTERY HELP 1998mom Lighting & Electrical 5 07-25-2013 09:43 AM
Serious problem, battery charged, battery dies after 1 min after starting truck. Help TigaHotty85 Lighting & Electrical 16 06-17-2013 03:10 PM
New battery, Alternator good, battery charge fading chevyman93 Lighting & Electrical 4 12-17-2012 05:59 PM
Draining on New Battery..didn't happen with the old battery tnw912 2nd Gen S-series (1995-2005) Tech 1 01-05-2010 05:27 PM
Remove Door Panel thanser 2nd Gen S-series (1995-2005) Tech 2 12-12-2005 08:15 PM
Tags
04, 1998, 2000, 98, battery, blazer, change, chevrolet, chevy, disconnect, needed, removal, remove, removing, tools
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
