2002 Blazer Shift Indicator and Odometer Issues
Hey there Blazer Forum! I just recently got a 2002 Blazer and the shift indicator lights and odometer lights do not work. After doing some reading online, it seems as though the most popular cause is a bad solder joint on the board. I re-soldered this joint (it's supposed to be a shared ground between the two) and still no luck. Whenever I plug the board in and apply pressure to the board between the two displays, they both come on. I'm thinking it could be in the connector. Thanks in advance!
swampdonkey
12-31-2014 09:54 AM
Brian.evans
04-18-2013 09:00 AM
Bl4z3r
02-10-2009 08:39 PM
