Mod to run fog lights as cornering lights?
Wait, how are you planning to make the fogs come on then? Just a switched +12v source tapped into the turn signal wire? If that's how you would do it then you'd want the diodes between the turn signal tap, and the switched +12v for the fog light function.
If you aren't going to use them as actual fog lights anymore, you don't actually need any diodes.
