Need a sealed battery
I need a sealed battery for my dual battery setup. What do you guys recommend. It needs to be some what small though. I have a yellow top that is a little too big. It is roughly 10x8x8 thats leaving room for terminals. It is going to run all of my accessories (6 driving lights, amps, cb, winch, and whatever else I decide to hook up).
optium-i assume you already had one by the yellow top
agm batteries -absorbed glass mat http://www.concordebattery.com/
yes i have an optima as my main battery. Im also looking to keep it in the $200 range. I didnt see any prices in that link but by the looks of it they are expensive.
just curious, where are you putting the second battery and how do you plan on hooking it up, Battery isolator? also would love to see some pics after its installed!
yeah i was looking at kenetic's. Will this one be ok http://www.onlinecarstereo.com/CarAu...ik_KHC800.aspx. or should I go with a higher wattage.
Its going in one of the side compartments in the 2 doors. I will have an isolator. I will have lots of pics coming soon as Im not driving the blazer for the winter so I have a lot of projects.
nice, never thought of putting one there.
so, will an 800 watt kinetik battery work fine or will I need a 1400w
Go with the biggest you can fit. If you can squeeze the 1400, do it.
donnieb83
08-02-2008 08:05 AM
Psychropod
21
01-29-2008 02:37 AM
