O2 sensor wiring?
O2 sensor wiring?
My check engine light is on. Codes report that my o2 sensor for bank 1 sensor 1 is bad. I replaced the sensor just to have the check engine light come back on. The only other thing I have notice is that there is some sort of missing wire on the top end. Could this be the problem? Help is much appreciated. Thanks. 1998 Zr2 4.3l
Last edited by superman6918; 08-21-2013 at 05:05 PM. Reason: Year and vehicle type
DTC's never tell you to replace a part, they tell you what circuit malfunctioned. It's the resposibility of the tech to follow the correct flow chart and determine what caused the malfunction. What DTC's did you retrieve? If there was more than one, what order were they retrieved in?
phxjosh
10-30-2013 10:03 AM
speedhead
03-16-2012 06:54 PM
nineteensixtycaddy
09-12-2010 08:54 PM
aspenpup
03-07-2007 12:17 PM
