Park Neutral Safety Switch Problem
Old 07-29-2013, 11:09 PM
Bomber77's Avatar
Bomber77 is on a distinguished road
Exclamation Park Neutral Safety Switch Problem
I'm trying to bypass my Park Neutral Safety Switch but I'm need a wiring diagram to show me which wires are for what. Can anyone help me out? I need to drive this thing to work in the a.m. so I'm running out of time! I'd appreciate any advice/help. Thanks!
Old 07-30-2013, 12:10 AM
WitchingHour's Avatar
WitchingHour is an unknown quantity at this point
Does your have the floor-mounted shifter or the column-mounted shifter? If you have the floor-mounted shifter, you pull up the boot, and there's a button on the left side of the shifter to override the shift interlock mechanism.
Old 07-30-2013, 12:43 AM
cubawashere's Avatar
cubawashere is on a distinguished road
the only thing that switch is doing is preventing you from cranking with the key if in any gear besides neutral or park.... if you need it to start in a jam and can't figure out the wiring, turn the ignition key to on position (MAKE SURE IT"S IN PARK -maybe even use parking brake) turn the wheel far left to gain better access to starter, then go to starter and jump 12v to little post on solenoid (purple switch wire-almost positive on color) that will make starter crank...it will stay running if key is on.
Old 10-06-2013, 10:08 AM
Teresa Queen-ofgeese Cockfield is on a distinguished road
Default Park neutral saftey switch problem
just replaced the switch still will not come out of park. Help
Old 04-01-2014, 09:49 PM
what switch did you replace? @TQofC
blazerfatman
08-04-2011 12:36 PM
kship3
10-16-2010 03:24 PM
metcalfr
11-23-2009 01:07 AM
95_4door
04-14-2008 07:39 PM
blazerssuck
12-05-2006 08:14 PM
Quick Reply: Park Neutral Safety Switch Problem
