Radio blinking.
Radio blinking.
2000 Bravada, I got it from my buddy and he hard wired an aftermarket radio in it but kept it and gave me the old radio but not the harness that goes with it... Anyway I got a new harness and am attempting to rewire it back correctly. Power is orange, ground is black, and ignition is dark green. Well I wired these three together just to test it and the clock and radio display just blinks the time or station. I hooked the radio ignition wire to constant power and it stays on fine. Fuses are fine and I tried unplugging the battery and letting it set but still the same issue. Help please?
Simple..You have to place your question on the right topic.Click that topic then start typing.When I`m talking about topic, I meant is it an electrical problem, motor problem etc..each problem you have will fall under a different category.I was like you when I too was a newbie.As time passes the more you learn
Boiler20
10-19-2013 03:53 PM
dan_t
11-25-2010 08:35 PM
iamchevyman5
11-07-2010 01:20 AM
