Under Hood Light Fuse
Old 01-15-2011, 07:48 PM
blueblazerguy's Avatar
blueblazerguy is on a distinguished road
Default Under Hood Light Fuse
What amp fuse is needed for the under hood light on a 1986 S-10 Blazer? I know it's one of those short ones, but what amp?
Thanks.
Old 01-20-2011, 12:27 AM
Blazers.B.Kewl's Avatar
Blazers.B.Kewl is an unknown quantity at this point
I think i replaced mine with a 1 or 2 amp fuse. Check your owner's manual for the power rating of the bulb (my manual has it but I don't have the manual at the moment) and then do the math. Power = current x voltage (or PIE as i remember it) for this application you want current so it turns into Current = Power / Voltage. Power will be whatever the manual say it is, and voltage is 12V. Whatever number you come up with is how much current is going through the bulb so get a fuse rated slightly higher than that number. Annd, you're all set! good luck!
Old 01-20-2011, 02:10 PM
radiokid's Avatar
radiokid is on a distinguished road
any thing under 5 amps should be ok.. the guy posted above me has the math formula you may use that method
Old 01-20-2011, 08:35 PM
Thanks. I put in a 3amp and everything seems to be OK.
Thanks. Did the math to check and put in a 3 amp. So far everything looks OK.
Old 01-21-2011, 07:19 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Supposed tp be a 4 amp but whatever is working you is good.
Old 01-22-2011, 11:54 AM
Thanks for the update. When I did the math it came out 3.XX, so now that I look at it a 4 amp might have been better. I'll keep an eye on the 3 amp I have in there and see what happens.
Thanks again.
Old 01-22-2011, 04:42 PM
neex's Avatar
neex is on a distinguished road
....stupid question but where is this fuse? Mine on my 95 went out and I can't find an inline fuse. Maybe it's hidden in the socket base or molex or something? Sorry to steal the thread but it seemed relevant...
Thanks!
A.
Old 01-23-2011, 12:31 AM
Don't know where yours is but on my 94 it's between the light and juction block mounted on the firewall.
Old 01-23-2011, 11:28 AM
Same place on my 1986. Just follow the positive wire back from the light. Negative wire connects to the firewall.
Old 01-24-2011, 11:55 PM
neex's Avatar
I don't suppose anyone has a link to a pic or a part, etc? I did trace the wire on my 95 and came up with nothing. I guess it could be aftermarket and wired differently. It's nice to be down to this as the last issue with this truck.
Thanks for the help nonetheless.
A.
Quick Reply: Under Hood Light Fuse
