stiff ignition cylinder when cold
Old 12-26-2012, 07:24 AM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
Default stiff ignition cylinder when cold
When it is brutally cold out (talking 20 or colder) when I start the truck in the morning, or after its been sitting long enough for the interior to be cold as outside, Its really tough to turn the key, not tough enough to where something will break, but stiff enough that if you are not holding onto the key to turn it to run after the truck is started, it will keep it in "start" for a second after its running, keeping the starter engaged, which obviously is a problem, if you dont want to screw up your starter or flywheel.
Is there a way to lube these things to get them to move more free when its this cold?
Old 12-26-2012, 07:29 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
I noticed this with mine once or twice,then when i swapped my column the other week it stopped. (i got the easy way out button)
Only thing i know is the old grease is dried out..you might have to pull it all out and clean it,and regrease it. Heck,try putting some graphite lube in it. its dry lube that worked great in my doors bolt lock lol.
Old 12-26-2012, 12:26 PM
serrasalmus's Avatar
serrasalmus is on a distinguished road
mine does the same thing good question rich
Old 01-01-2013, 11:34 AM
wannabelifted's Avatar
wannabelifted is on a distinguished road
mine has started doin this too, 93 blazer. thanks for the info
Brian5792
10-24-2018 11:34 AM
mbar
11-10-2010 02:39 PM
kvesi122
03-25-2010 11:48 PM
Chevy Lover
08-02-2007 11:06 AM
lochenjons
Suspension Tech
08-25-2006 07:54 PM
Quick Reply: stiff ignition cylinder when cold
