Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
Any thoughts? 04 lowered and hitting driveshaft
Old 03-20-2016, 04:02 PM
Hunga Ku Candella's Avatar
Hunga Ku Candella is on a distinguished road
Default Any thoughts? 04 lowered and hitting driveshaft
Buddy of mine had an 04 that he lowered 3" in the front with lowering springs and in the back used 4" blocks and removed a leaf spring from both sides. For as long as I knew him it never gave him any issues minus a somewhat rough ride and not being able to go over some of the bigger speed bumps some places like to use but a couple years ago 5 of us tried to take a ride in it and even tho it would move it made this AWFUL noise. I just bought it and have been trying to conquer the problem myself. I read around a little and have installed the belltech nitro 2 shocks in the rear instead of just the regular stock ones and it made it better but still get the rubbing. At this point I am wondering if taking out the one leaf spring from either side and having 4 12" subs in the back since he first got the vehicle has caused the remaining springs to lose some strength and support causing it to sag more and rub. Any thoughts or ideas would be greatly appreciated and thanks in advance
Old 03-20-2016, 08:57 PM
The sole purpose of a shock absorber is to dampen the action of the spring. It does NOT affect ride height. The spring determines the ride height. You answered your own question... Removing a leaf from each side weakened the springs to the point where they are not strong enough to lift the body up where it belongs.
Old 03-21-2016, 07:41 AM
Thanks for the input! As you can most likely tell, I'm still somewhat new to understanding how the suspension works but I'm determined to learn and to fix
slamdblzr
Lowering Tech
16
06-05-2019 07:47 PM
gitch93
01-23-2013 04:51 PM
chcknugget
28
12-13-2011 08:21 AM
lynxxyarly
36
12-06-2009 03:45 AM
Scooterewski
03-23-2008 09:24 AM
Quick Reply: Any thoughts? 04 lowered and hitting driveshaft
