2000 blazer w/ "service 4wd" light on?
Old 05-29-2011, 04:10 PM
mud_yeti87's Avatar
mud_yeti87 is on a distinguished road
Default 2000 blazer w/ "service 4wd" light on?
i have a stock 2000 blazer LT with the push button 4wd and the service 4wd MIL is on. It won't shift out of 2HI either. possible issues?
thanks in advance
Old 06-08-2011, 12:16 PM
Volff's Avatar
Volff is on a distinguished road
Hey Bud,
I have a stock 2000 LS with the push button 4wd, I have the same issue, what i've been doing to get mine in and out of 2Hi and 4wd is theres a connection located under the hood near the hood light, I've been disconnecting that to get in and out of gear. What im going to do is take to a garage and have them dismount the front shaft and check the transfer motor, I replaced the motor when i purchased mine and it seemed to help but, still have the occuring issue
Old 06-09-2011, 05:05 PM
mud_yeti87's Avatar
i've decided to do something that a buddy told me about. you go to a scrap yard or swap meet or wherever you'd normally get 2nd hand parts, locate an NP231 floor shift T-case, get the shifter cable, shift lever and bracket, and centre console out of a pre-'97 blazer/jimmy/s-10/sonoma that had a flor shift and swap that in. and to completly get away from vacuum lines, you swap the extension housing of the front diff with one from an AWD safari/astro van. i got all the parts i needed from a local scrap yard for about $60
BLAZE86DUBZ
05-11-2014 03:02 PM
Geir
10-09-2011 08:51 PM
slowtalker
02-17-2010 08:52 PM
2001 ZR2
01-16-2010 12:39 PM
99blzr
12-30-2009 12:18 PM
Quick Reply: 2000 blazer w/ "service 4wd" light on?
