Do you think I can run 38's
Old 01-19-2009, 10:08 AM
jeepster82's Avatar
jeepster82 is an unknown quantity at this point
Default Do you think I can run 38's
http://i496.photobucket.com/albums/r.../blazer001.jpg
I have 36's with no rubing Do yall think I can get away with 38's?
Old 01-19-2009, 10:13 AM
Default RE: Do you think I can run 38's
I think you will be damn close. How close to the frame/body do those 36"ers come when you are at full lock with flex?
Old 01-19-2009, 10:25 AM
jeepster82's Avatar
maybe about a inch from the flares, depends how big of a rock I get on.
Old 01-19-2009, 10:32 AM
Default RE: Do you think I can run 38s
They you would probably hit with 38s. Have you done any trimming?
Old 01-19-2009, 10:35 AM
jeepster82's Avatar
No everything is stock, what could I trim? my flares?
Old 01-19-2009, 10:37 AM
If you have to, you could trim/bash the wheel wells in the back to gain additional clearance. If you are within an inch at full flex, you will be close.
Old 01-19-2009, 10:40 AM
jeepster82's Avatar
Thanks, I just bought these tires so when they go I might get some 37's
Old 01-19-2009, 12:35 PM
WolfPack's Avatar
You'll have front axle problems with anything bigger than what youve got. If you want to go with 38s, go SFA and swap the rear axle.
I wouldnt be suprised if you snap a half shafts if you do any heavy offroading with your current setup.
Old 01-19-2009, 12:40 PM
jeepster82's Avatar
ORIGINAL: WolfPack
Honestly I have never had any problems, I do some hard rock crawling. All I did was regear with lockers.
Old 01-19-2009, 01:01 PM
WolfPack's Avatar
Give it time You'll SFA eventually
Quick Reply: Do you think I can run 38's
