Lift kit and tires
Lift kit and tires
I have a 1990 Chevy blazer. I want to lift it either 2 or 4 inches and get bigger tires. Any recommendations on where I can find good deals online? Also, what size tire do you recommend I upgrade to? I currently have 31x 10.5 on there. Thanks.
ED
ED
Oh. That makes more sense. As to the K5's I am clueless. Maybe Rough Country has a lift for them? If anything you could probably find a simple body lift and put that on to gain 2-3 inches. And as for tire size, like I said, I'm clueless. Sorry bud, hopefully one of the more K5 knowledgeable guys will hop on and help you out.
Thank bud. I'll look into rough country
yeah i owned a few k5s a 4 inch lift and 33s. you can fit 35s under there if its just a street truck as they will hit off road but probably be better with a 6inch lift
k5 lift
I had a k10 pickup a few years ago. I put a Progressive Suspension 4 inch suspension kit on it and ran 33x12s with ,o problems. Might need to replace your wheels and adjust backspacing, but I had no clearance issues in the front. My truck had a flatbed on it, so I'm not sure if you would need to do trimming back there. With 33s my guess would be no. 35s would have certainly required trimming or a body lift. Pretty much what abig84 said. 35s might work on a street truck with a 4 inch kit, but on my truck I had very little clearance (half inch maybe?) up front at full lock, so even small articulation would have made it scrape.
With 3-4" of lift you won't have to mess with the drive shaft. I'm almost certain you don't even with the 6" suspension lift kits. Anything beyond that would probably require a longer drive shaft.
