After market tail lamps/lenses
Hoy all, just though I'd post a little problem, with the after market tail lenses I bought. I put these on after I bought it. I noticed this spring the red inner lenses getting what I thought was condesation. But what it was, the lenses were starting to melt. This is due to both rear tail/brake/turn bulbs sharing the same lens.
Darn shame they melted, for I really liked this design. But I did come up with a solution to the problem. Instead of using two incondesent lamps, use one incondesent and one LED bulb. That would cut the amount of heat in the single lens.
Of course I thought of that solution after I bought the Altezza dual lens type.
Don't make the same mistake I did.
RE: After market tail lamps/lenses
can u say junk..... If you still have your orig set i still do the custom painting, like i beleive i had mentioned when yougot the truck..Lemm know if ya wanna try a set like mine i just did a set for another member on the board here but their not on his truck yet..
I purchased the same, or very close to Altezza dual lens type for my blazer last year. I didn't like the way they looked at first. The edges were clear and you could see that they used a white silicone to seal the seams, which on my blazer with black trim looked really tacky. So I took them off, ran some tape around the edges and covered the lenses and painted the edges/seems black and they look totally different and much better. I just used a black gloss krylon plastic spray paint on them and they turned out excellent! I only wish i would've thought of it sooner!
The heat off the normal light will kill that LED. LEDs have a very strict heat range and if that bulb was getting hot enough to deform the plastic I'd be really worried about that LED.
Shane Blume
TrailBlazer GMT360/GMT370 (2002-2009) Tech
03-04-2013 06:41 PM
