dead power seat
dead power seat
got a 99 Bravada with heated power front seats. the driver side works fine but the passenger side is totally dead. its a pain to sit in as well since it died in a weird position, most of the way forward and the reclined far back. im thinking its a bad power motor if thats the case how hard are they to swap out?
does it move in any other direction ??
should be more than one motor
If no other function is working check the fuses , for some stupid reason I think the left and right seats are separately fused
If the fuses are ok also check the power plug under that seat
ill check the fuses if thats the case maybe there is no power to that seat. i turned the heated seat on and it didnt work. that seat is completely dead no movement no life nothing. i read about 3 wires for the power seats going across floor pans under the carpet then they fuse into one wire by driver kick panel. maybe my truck is too new but ill check
ok i checked all the fuses could not find anything that specified the power seats. looked in engine compartment fuse block too. i found the heated seats fuse was blown so i replaced that one and the passenger seat still didnt work
yes the connection on plug is clean and connected..and yes had owners manual with me looking at the fuses and cavity. the only think i didnt do was check for voltage at the plug
94s10blazin
08-10-2013 01:00 PM
LilMsChevy
01-11-2010 09:45 PM
