LED Flasher
LED Flasher
Wanting to convert the exterior lights to LEDs. I have a '00 Grand Prix GTP that I have compelety coverted to LED's and was able to find a flasher for it to fix the hyperflash issue. What I need now is a heavy duty/LED flasher for the Blazer. I guess another question is where is the flasher module located on a 99 2dr blazer and also if anyone has info on where a LED flasher can be bought from. Thanks.
RE: LED Flasher
Most flashers will be in the passenger side dash. Depending on the model, your glove compartment should open like this:
If you look in the bottom right of the space behind the glove compartment, you should see a bunch of small wires, The signal flasher is to the right of them.
As to where to get the flasher from, autozone, pep boys etc. should have plenty of them.
ORIGINAL: Eurogoldls
Thread: https://blazerforum.com/m_78530/tm.htm
Just push the metal clip up:
and the glove box will completely fold out:
RE: LED Flasher
Thanks for the info, greatly appreciated.
RE: LED Flasher
You're welcome. I didn't mind in the slightest!
RE: LED Flasher
I went out to the truck shortly afterwards and found it. Wasn't sure how to get the green retainer strap off so I moved it off to the side without actually detaching it. Seemed to work.
RE: LED Flasher
yeah thats what i did when I changed the one on the Sonoma.
RE: LED Flasher
ORIGINAL: EuroGoldLS
RE: LED Flasher
Yes good side note.
96jimmyslt4x4
09-21-2011 09:14 AM
96jimmyslt4x4
05-29-2011 03:55 PM
apekim
09-15-2007 10:46 AM
kccapt
11-23-2005 01:34 AM
